kelly.ga
Another bad product, maybe, maybe not. As I posted a few day ago, I had worked my b--t off until 9:30 pm, was soaking wet, ticked off, and still did not get the rear window in my 47 coupe. Today I tackled it again with the help of Lawson Cox, and we had the same result. Now, since the opening is still the same, and the glass is still the same, you would think maybe the rubber is at fault. However, in this case at least, the glass is not original so maybe I have a defective glass size. My question is, should the glass pass thru the opening without the rubber. This is the only way I know of to determine if the glass is the correct size. On my car it will not pass through. My next step is to have the glass downsized by about 1/16th of an inch alll the way around. So, what do you guys think, should it pass thru or not. Thanks to all you guys, you always come through.
