jerry shook
Bob. The lights and horn are hooked to the alternator. I appreciate all the help . Never had anything like this before. And i am sure when the problem is found, it will be something simple always is.
Steve. .... I also noticed every thing works even with the fuse on the starter out, there should only be fire to the starter with the fuse removed.
To bob and steve and all that helped thanks. T dont know what was wrong but after i put the wires back like they were the amp gage started working only backward so i put the yellow on the driver side of the amp and the yellow with tracer on the passenger side it works right now. Thanks jerry
... Problem is weather the fuse is in or out there is fire to everthing. Lights horn car will crank, help!!!!
well shut my mouth ! im having the same problem . amp gauge only shows discharge but no charge .......... hmmmmmmmmmmmmm .. steve
