Alternator & Ammeter
I'm contemplating installing a 60 amp alternator in my 29 Closed Cab Pickup. Should I change the ammeter to a 30+ - type?
Rich Largent
Yes, and don't forget to reverse the wires if you are converting a positive ground system to negative ground.
You can also run a jumper wire across the ampmeter to carry part of the current. Your ampmeter will no longer read correctly (you need to mentally adjust the reading) but it will look original. I think you can install this jumper at the terminal box on the firewall. What are you going to do with 60 amps?
Charlie Stephens
It is not necessary. The ammeter is not showing the output of the alternator but rather the battery charge rate. The alternator unlike the generator has a regulator that limits the output to the amount of the load plus a small amount to keep the battery charged. Because of the regulator the ammeter should read near 0 most of the time. It would be possible to exceed 20 amps very briefly if the alternator were trying to charge a dead battery but the original ammeter is very resistant to overcharging damage. I would not expect this be an every start condition.
I have an alternator on both my cars. One is a 6 volt, the other is a 12 volt. Both have the original ammeter. When I first start either car, and pull power out of the battery, the ammeter pegs over to the 20 showing the alternator is charging the battery back up at a high rate. After a while it pulls back to zero. It has been that way for years and has not done any damage to either ammeter. The existing shunt in the ammeter is apparently stout enough to withstand the high current.
As posted above, even though an alternator is rated at 60 amps, that much current is not going to go to the battery.
Tom Endy
The link between the current and the needle is magnetic. Once the needle is against the stop increasing the magnetic field pushes harder against the stop but does no damage.
A weak point in the ammeter is the connection between the posts and the brass shunt. The posts are a carriage bolt that fits thru a square hole in the shunt. A loose connection here causes the meter to get hot and even burn. Increasing the current could cause a poor connection to fail sooner. I usually solder the bolts to the shunt.
