harleytoprock
I'm installing Snyder's EZ-steer teflon kit. The instructions state that the springs should be tightened 25%. The springs free length is 1.000". So, do I tighten it till the spring is .750" long? The spring will coil bind at .735". Does this sound right? You may think that I'm over thinking this but I fear an incorrect adjustment could add steering free play or worse a ball could pop out. Thank you for help!
