I guess I should explain a little more about what I'm working with. My model A came with a diamond block B engine. The stock model A transmission was still there so the back of the pan was cut off to mount to the stock flywheel cover. I am going to run a T5 behind that model B engine and have a Dwight Bond adapter that bolts to an AA/BB 4 speed bellhousing, which I also have. I just got me engine back from Antique Auto Ranch and started looking at stuff and the flywheel cover is no where close to matching up with the bellhousing. The 4 speed bellhousing I have is out of a friends '32 BB truck so is there a difference between the AA and BB flywheel cover?? His truck had a B motor in it in front of this bellhousing but the flywheel cover is gone. I'm cornfused.
