Guys: I appreciate what you are saying, similar concept to what everyone thought years back when four bar front ends became the vogue.Now everyone is going back to split bones or hairpins. I was building a traditional flatty powered 32 back in the eighties when all this four bar stuff came up, my car had split bones. I jacked the front up and disconnected the spring shackles. I was able to rotate the axle way beyond any travel distance you would ever experience in driving, No axle twist or bind, felt safe after that. Drove the wheels off that car,looked at the welds and wishbones pretty regularly no problems. My 32 tubster has a ford 8 inch rear hung on 36 wishbones with a 36 rear spring, attached pretty much the same up front as this A, 20,ooo miles looks great. Then again my 50 merc motor is lucky to put out 150 hp on a good day. If it had a hot modern v8 that would be a completely different story. Then again it wouldnt be too hard to add two triangulated links from the top of the banjo bolts over to the side rails. Cant wait to drive the rts four speed Its light as a feather the stick comes up in almost the right spot welded on an early ford stick this am ,just have to find a tower cap that looks more like an early ford. Too bad they only made these a few years.
Maybe you should write a book! Damn nice job...It's finally up on wheels a lot of work! Boxed frame, my own x member, 39 pedals, f1 steering with a model a snout grafted on, 40 column and wheel. Had to graft on a piece of 34 steering shaft to get from splines to a keyed taper. Did my own springs,front and back. Reversed the arches in both main leaves with my arbor press. Ground and tapered all ends, very soft, might have to add a couple of leaves to the front. Should ride nice. Brake plumbing, exhaust next, then paint and hopefully final assembly.These are mostly junkyard and swapmeet parts. Its a lot of labor, but a good lesson on how they did it in the early years.Driving it should complete the experience. Bought a rolling semi complete 29 roadster in minnesota. Driving up to the farm in N,D. next week will pick it up and trailer it home. Hope it is half as good as the pictures. Hope my new avatar picture doesnt offend anyone. I dont know who the girls are, just took their picture with my flathead powered tubster at a show at Don Garlits museum a couple of years ago.
Heres my AV8 although mine is a little different. I used a F-1 center crossmember to locate the transmission and pedals. The rear end is a 40 vintage I cut the torque tub and drive shaft down and used 46-48 short arms on. I also cut some Model A rear spring hangers off some jubk tubes and bolted/welded them on the 40 rear to hang the T rear spring.
