Hey Chris you certainly captured the look! awesome car. Rich
Front spring leaves are pretty easy, I cant imagine doing that to a model A rear main leaf! Going to make up a fixture heat it up bright red twist the eye the other way. at least thats what I want to do. Any input on retempering.
Mike: I am talking about a model A rear spring pretty complex shape! Has anyone ever done this to one? Rich
I have reversed a rear spring useing the method and homemade jig from the HAMB. It is alot of work! I don't think I would do it again, You are right , that is alot of arch to turn around.Mike: I am talking about a model A rear spring pretty complex shape! Has anyone ever done this to one? Rich
I think the 1" you will gain could be had with lengthened the shackles ,but then you will need a stabiliser bar , By Removing three leaves then adding stiffer shocks could drop it down more, I dropped a 34 ,2 1/2 " by removing 4 leaves.
You cannot run a longer shackle on an A because the spring sits right over the rear end...not behind it. Longer shackles would make the spring hit the axle.
What he said. I spoke to a spring specialist about this and he said rolling the eyes the opposite way is bad practice, they can crack.I don't see any way that you will be able to correctly re-temper the ends of the main leaf; I think you will have a main leaf with "dead" ends and it will never work properly.
Regardless, fabricating a fixture and doing it yourself (time/labor) or finding a spring shop to re-roll the eyes for you ($) seems like a long way to go for the small amount of drop you will achieve. In post #15 Bassman's frame is Z'd; all Model A frames will require some fabrication and welding anyway so think how you want the car to sit and Z the frame accordingly.
What sort of adapter did you use to mount the transmission? I use the same ******, but I have only mounted it behind an 8BA block. Makes a great driving car. I have one in my 39 and grafted the 39 lever to the box. Shift lever is within 1/2" of the stock location.Hey Lee! Guess what I did while you guys were out for breakfast this morning? tacked in my front motor mounts, made up a little fan carrier, set my motor and transmission in place. Have to notch the center crossmember to get the back end of the motor, trans, up a little higher. Next thing to do is mock up my crossmember transmission mount/wishbone locator. Will do this in plywood first, then take template to Randy at Martin County Sheetmetal to have it cut and bent to shape. Besides 12 volt, my other modern concession is an RTS Ford four-speed overdrive. Going to cut off that ugly stick and graft on one of my old '39 sticks. Still fun up to this point.
Have this project at work - steal and hour (from myself) here and there. Work a little after work and Friday afternoons (we finish at 11:00 a.m. Fridays). If I had this at home waiting for me to do it evenings, it would still be a pile of rusty parts!
