'94 F150 E4OD trans control lever
F-150 guy
My daughters '94 F150 E4OD trans control lever the cover on the end of the lever has came loose and slides off as far as the OD on/off control wires allow it to. Is it OK to gorilla glue it back or will that make it difficult to repair/replace the OD switch if repair/replacement become necesary?
The cap is fairly inexpensive and was still a good number from Ford as far as I know.
Part number should be F2UZ-7A241-CA. The little plastic tabs break on them. Sold
quite a few thru the years...
Thank you fellows for your replies. One more question. How does one disconnect the wires to the OD switch and reconnect/reinstall the switch on the new part and fasten it on the lever? I have AMD and cannot see details very well/ Thank you.
Thanks guys for the replies and advice. Her husband took care of the problem. He's not much in to working on vehicles so that kinda surprised me.
