Reelnative
I bought a semi basket case Roadster Pickup, previous owner bolted the cab to the frame with the old wood and misc bolts. The doors didnt align, I ordered new wood and bolt kit, my questions is, where the front cab bolts to the frame, does the long wood piece go inside the channel? I did that but after adding the other wood blocks its way off. The door is to low to the the back of the cab, I know it requires some tweeking but the front cowl mount seems to low. With the wood inside the front channel should there be anything between the cab and frame other then then the rubber cushion? Please help, I am at my wits end!!
