8ba Mallory dizzy cap
Anybody know where I can get a black dizzy cap for 8ba Mallory duel point?
I bought a black 'distributor cap' for a Mallory from NAPA.
Believe it was part number ( ECH MA 2 ) about $25.
Replacement for 209 series 'red' cap.
This doesn't make any sense to me?
When is the last time in several decades that Mallory made a contemporary design Ford flathead distributor that came with a black distributor cap?
The cap he needs was used on all flat top Mallory dizzies. They are out there at every swap meet.
Easy bro.........he said it in #1...........perhaps not to the inth degree, but we knew.
Charlie ny
Now I am confused because this is also an " 8ba Mallory duel point" ?
450744
Nowhere was it stated that it was an old flat top distributor.
Thanks, Charlie. Maybe I was assuming it was a flat top, but that is what we all assumed he was talking about. To be clear, the "flat top" cap is a two piece deal with a water sealing gasket sandwiched in between the top and bottom pieces.
If not, then he's in luck for any Napa should be able to help with for around $20.
Edit: Look at post #8. 51 Merc CT even has the part number for the "modern" style replacement cap.
He needs a Mallory 4001 cap. Napa has a replacement cap in conventional style
Echin MA-5. $25. Matching rotor MA-7.
Cheers
Tony
Seems as though the OP could put an end to this quandary by posting exactly what he needs and what for, but for some reason chooses not to.
