8ba in 36 5 window
mfagan
Has anyone any experience in handling steady rod installation on an 8ba in a 36 5 window with a 39 transmission.
Any ideas or help would be appreciated.
Marvin, you may have to turn/grind forged stop off, then run a thread die on for 1" or so. Spin first nut down to have adjustable stop. Trap bellhousing with second nut. Lock washers.
Look at 19forty links. best to my knowledge the fan becomes an issue, thought about doing it once. Angled radiator on a 36.
Truck engine parts will link to a earlier transmission. Waterpumps needed too and the oil pan. Trucks still had a straight axle. Had a cracked truck block with all the goodies. Pasted it to a club member.
Some more to read
https://www.fordbarn.com/forum/showthread.php?p=991078
https://www.jalopyjournal.com/forum/threads/mounting-a-8ba-flathead-in-a-36-ford-coupe.243922/
Some more... on 8ba/rt to 39 trans.
https://fordbarn.com/forum/showthread.php?t=161099
Best of luck, hope to see the progress!
Am I the only one who doesn't understand meaning of the above post?
Please clarify.
Seems fairly clear to me. Not sure I totally agree with the approach, but I understand what is suggested. 34p-kup is recommending grinding the original flange off (most likely forged, not case) so the stay rods are a consistent diameter. Then using a die to thread the section where the flange was and using a nut on either side of the hole in the bellhousing/block so that the effective length of the stay rods are adjustable. The issue I see is that the 8ba does not have the holes required for the stay rods, correct. So, a plate needs to be added to accommodate the rods.
Thank you for clearing that up for me. When I installed an 8BA in 40 Ford I welded ears to the stamped steel Merc bellhousing. Made shorter rods and sold the originals. Worked out fine and dandy.
