geocorse111
Hello members, looking for some assistance with fan belt and gen/water pump belt install. I picked up a 1951 F3 with 8ba motor, when purchased the radiator was out as well as generator, and fan pulley assembly. I had the radiator and generator reconditioned and purchased belts from NPD. The belt for the gen/waterpumps went on snug, the belt for the fan seems long. I am installing the fan pulley assembly with the adjustment slots, I'll call them, up and the fan pulley is below. Any other way it seems the fan pulley will interfere with the generator. The fan belt is listed in manuals as 8ba-8577, NPD # F-8620-5a. The bag says narrow fan & waterpump belt from Dennis Carpenter, the other tag says Drive belt, engine assessory, 48-52 F1-3 239 NPD. The belt, when stretched measures about 21 1/2 inches. Can anyone tell me what the fan belt length should be? The next question is how do you adjust tension, easier with radiator out which it is, but do you adjust the gen/pump belt first then the fan belt?
