I have a wiring diagram for a normal 3 pin thermal flasher for my turn signals but want to use LED's rather than bulbs. The Victor Auto Flasher EF32 mentioned below is a two pin flasher. How is this wired to the turn signal and what happens to the wire that normally goes to the third pin?
Found this 6 volt LED flasher on Amazon. Looks like it's built similar to Tom's homemade flasher using a relay.
