I removed the previous caretaker's 1 wire, 12V, out of place alternator, regulator and drop resistor to use an original 6V generator & regulator. I rewired that circuit while I was at it. Where did Henry originally ground the wire from the generator ground terminal on the '40 ? Thank you Fordbarners.
