221239ford
I recently replaced the tail light bulbs in my stock '50 coupe with LED bulbs. The bulbs work great but do not pull enough resistance for the turn signals to function properly (blink too fast). I found a source for a 6 volt electronic flasher for use with LEDs but it is advertised for a Porsche. I don't know if Porsche was a negative or positive ground system. Would the flasher work in either a positive or negative ground system? My thinking is it is just a switch but I don't want to fry my wiring harness. Any thoughts?
