stewgee
Hey all. I'm new to the Forums so bear with me. I am having issues with the 6 volt starter coil on my 30 A. I pulled the engine, replaced all seals and gaskets and reinstalled it. It was starting and running fine before but was leaking oil profusely. Hence pulling the engine and resealing. The problem I'm having is I can't get a spark from the coil to the distributor. I replaced the original coil with a new NAPA 6 volt coil and still no spark. Installed a new wiring harness except for the wire from the generator cutout to the firewall junction box and from the starter to the junction box. I replaced these wires with 16 ga wire. I followed the wiring diagram and have unwired and rewired 3 times and still no coil spark. Anyone have any ideas or suggestions? Any help would be greatly appreciated.
