That block doesn't scare me upon initial look. I'd want to know more about the front crack in the water-pump area. With a little bit of work, I'm sure the front area could be pinned and the crack could be stopped from progressing - as JWL said, it was probably dropped or hit on the front (has nothing to do with freezing). If the crack doesn't go into the side of the block, then once fixed the water pump should seal - no big deal.
I don't see any freeze related cracks and the lifter bore appears to have a chip out of it (not an issue). I'd have it pressure tested and then make a decision.
Also, you might let us know how much $$$ they're asking for it - that could influence my decision making process.
