57 y block
Randall
Anyone have a picture of puller for crankshaft balancer? The pulleys are riveted on and a standard puller no work
Thanks
Make one. short chunk of flat bar (that will fit into slots of damper) bore and tap a hole in center for pressure screw. I used a pressure screw from a heavy duty steering wheel puller. Use a short bolt in crankshaft to center pressure screw if screw doesn't have a wide enough base to keep it out threads CS.
Here's another example of the same T-bird damper puller. I've used it twice and loaned it out a time or two. I bought it back in '12 at a slightly lower price. It works great and I don't regret the 'pricey at the time' purchase like I thought I might.
Currious Randall. Are you just rebuilding your damper, or are you replacing the front crant seal and timing chain while you're at it?
