Milt K from Pa
Barners,
I was not expecting to adjust my timing, but during the installation of the tach drive cable, I found out the hard way that the distributor bolt was not tight, the distrib turned. Now that the carb is back on, I wanted to set timing. With the line disconnected from the distrib end, ( and capped to hold vacuum), I connected a vacuum gauge to the manifold line. I started it and found that with maximum vacuum, I was spinning the distrib fully clockwise for max RPM and VACUUM. The timing marks were about two inches from the pointer,(advanced)and it ran smooth. If I moved the timing pointer near the marks on the pulley, the engine would run really rough. Vacuum with the distrib fully clockwise was 19 to 20 lbs mercury. It dropped a lot when set near the marks.
Anything come to anybody's mind on the problem. I was hoping to set the initial timing to 6 to 8 degrees BTC, as described in the manual.
Thanks for any assistance
Milt K from Pa.
Milt K from Pa.
