KULTULZ
Is the throttle linkage bellcrank the same for both automatic and standard transmission cars? Sounds like a silly question I know but I have a 56 Victoria that originally came with a 292 and automatic and now has a 312 standard with overdrive.
When the gas pedal is depressed the carburetor arm on the bellcrank hits the firewall before the carburetor is fully open. I don’t know if the original 292 had a two or four barrel. It currently has a Teapot. If the linkage between the carb and bellcrank is shortened the bellcrank arm going to the accelerator bottoms out on the firewall. Still won’t open the carb fully.
OK... Let's try this again.
Your particular application does not use the intake manifold shaft and bracket, but there is a difference in the ACCELERATOR ASSY (9725) (firewall mount) between AT and STD.
Good Used 1956 Ford 272 292 312. Fire wall to gas pedal Throttle Linkage 2 & 4 Barrel Carburetor Std 3 Speed transmission. Missing is the straight rod to carb. May have one to sell inquire.
