My power seat just stopped working. When I try to raise or lower it I just get a clicking noise from the relay for that motor. When I try foreword or backward I get the same clicking noise from the relay for that motor. I removed both motors and bench tested them bypassing the relays and they worked fine. Should I assume that replacing the relays will fix the problem? I will appreciate any input. Thanks!!
