I heard the stock '56 F100 hinges ones never worked well. But using a nice tight pair of OEM ones last night 3 of us worked hours to try to get this hood to coming even close to shutting. First of all when you shut it both rear corners are up SEVERALl inches,. You have to go back and push like hell on each corner sometimes that lifts the opposite side corner again...Plus I can only open it about a third of the way.It will hit the windshield if I would continue to raise it higher but I won't....Tell me how I know(cracked the windshield ) Now I have in the past on other Fords had to push down a rear corner a 1/2" or so but 8" or so is nuts.I am sure this has been addressed before ...But are the $600 billet ones the answer? Windshields aren't cheap either so???
