Anyone know where to get a pre bent window channel for a 56 Courier? Part 21550 in the drawing. Only thing i Have been able to find is a straight channel. I got one but trying to bend it buggered it up good so really need a prebent one. Thanks
I just replaced the window channel on my 55 ford wagon.It is kind of tough but I did it.
Start at the bottom and when you get to the corner,start shaping the channel according to the turn.Once you start making the turn,slowing start tapping on the channel as you bend it.Use a rubber mellet to tap so that you won't bend the chrome of the window channel.Once you have the turn,start pushing the channel all the way into its groove so that when you have it all inside the track,the little rubber holders will match the holes in the door.Hope this helps.
Mando
Try Tee Bird Auto. They have quite a bit for 55/56 sedans and wagons. Their stuff is pre-bent too
Got a link to them? I cannot seem to find them.
