52 Merc headlite ring
itsa52
GI
NE
I need (1) one headlite ring, inner and outer for a '52 Merc.
Let me know whe you have.. Pretty sure Ford and Merc 52-54 are all the same.
Hi,
I do have a couple of those headlight doors for the 52-54 Fords and Mercuries. They are not perfect, but could certainly be made serviceable. The inner stainless rings on both of these look pretty good and should polish up nicely. Both of the outer shells have some issues, one has some pitting and rust through near the drain hole and machine screw hole. The other one has a shallow dent in generally the same area with some loss of paint and some minor pitting. I think you could work with these and make them like new. If you think they will help you out, you can have them for the cost of shipping them to you. My e-mail is jen.toby@yahoo.com and phone is 802-869-2688 Thanks, Toby Lampert
Hey, Thanks to 39wdy, the Merc now has two good headlight doors, both with SS rings.. eeeeha.
Along the way and just in case anyone pulls this up years from now while doing a search, Ford and Merc are very definitively different.
Merc's are round, Ford's are oval, taller than wider, and narrower than the Merc. The Ford also has a bit of a "peak" on top.
Probably stamped from the same blank, just a bit different
