picked up this 51-52 ford eab truck engine its clean outside and it spins over good with a battery ant i pulled the cap off the dist. and fire on the points will eat u up so coils good and it has fairly clean oil on the stick guy took it out of the truck and its been in his dry garage ever sence so not been around and moisture or etc but the cap has a crack in it and the plugs are shot and it has 3 04 broke plugs with it spinning over i just wonder when i put new plugs and wires on it and new cap and rotor button and put some gas down the carb what are maybe the chances of this thing running ????? anyone had any luck with engines of this condition ??????? here is a pic of the engine i gave 300.00 for it and not one thing is gone off the engine . someone told me it having eab heads thats its high compression ??? and its high horse ?????
