I have a 1948 Flathead with a duel carb setup and I would like to replace it with a single carb set up.
The question is: "What problem(s) will there in replacing the 1948 dual manifold with a 1949 single manifold?"
I have the 1949 manifold sitting on the engine and it bolts in place, but will there be problems with a running engine?
I will not be using the mechanical fuel pump and I will still be using the stock 1948 ignition system.
Thanks in advance...Joebeeker
