My switch does not work....Does anyone know if these can be fixed or who might do it? Anyone have a Period Correct NOS or used interior light for sale?
Thanks.
Your dome light looks just like the one in my 1935 Truck. I drilled out the rivets and was able to get the switch working again. I re-installed it with small bolts. I just had to clean up the contacts. If your unit is missing parts, then it might be harder to fix.
I too have repaired these. Tedious work but worth the effort.
Typically, as has been previously advised, a simple cleaning of the contacts will do the trick. On rare occasion, I have found it necessary to build up a contact or two with solder.
Thanks, guys!
I too will look to repair...
Interestingly, 46 & 47 trucks Ford offered 25+ Period correct options, not many FofA trucks had anywhere near that, Ford of Canada had some & Mercury had many more....
Model51 may well be right, Interior lights may well have been left over from the 30"s....
Even back in 1935, trucks had many options. Attached is a list from the index for Chapters 6 and 7 of my book listing 40 options, some trivial, some came in pairs, but all are Ford supplied accessories for Trucks in 1935 or 1936.
The list is a pdf file so hopefully you can open it.
