Deuce Man
I recently installed an electric fuel pump in my 46, I wired it to a momentary toggle switch to be used as a primer or to overcome a vapor lock situation which is a frequent occurrence in this Florida heat. My car now runs too lean unless I run the fuel elec. pump thru the mechanical pump. If I bypass the mechanical pump, and remove it, I naturally would remove the pushrod. Will this effect my oil pressure? Many years ago I tore down a 59 block and there was a ground down bolt jammed into the pushrod hole, I always wondered why, Did some old timer know something we don't? By the way my now gone dad used to say " a cold beer was the best cure for vapor lock" I don't remember if you were supposed to poor it over the carb and fuel pump, or just sit there and drink it until your car cooled down! Thanks Rich
