Jacobs1946
Hi, does anyone know the torque specs on the 9/16 bolts that hold the banjo together and the 9/16 bolts that hold the torque tube on the rear. I cant seem to find the information anywhere. Thank you!
I don't think there are any torque specs available for those bolts.
When I bolted my torque tube to the 40 rear I just made sure they felt tight without forcing them. I also numbered each bolt location and made sure the same bolt went back into the same threaded hole it came out of. I would also do the same with the banjo bolts. May be a bit anal but, you never know when it comes to getting those bolts "right".
The original safety wire is in the right photo.
A torque wrench was not a common mechanic tool back then, oil pan bolts were snug, the banjo bolts were tight, the axle nuts were “ good and tight”—- put a pipe on the wrench
