42 pickup spare tire stand brace
Chet/Ma.
Wanted:large brace for spare tire stand that supposedly didn't come out until 1942. Part number 21C 1488 Lawson and I need one each. Thanks Chet
Thanks Chet. I finally found a picture and posted it above. I hope this helps everyone out. Lawson
Maybe some pictures attached.
Thanks for posting Dean. Could you do a tracing or something showing angles on each end and thickness etc. Your picture looks like it has a stiffiner bead stamped into it where the one on the picture I posted looks like it is flat, other than the 90 degree bends forming the channel.
I don't know what the 21C1488 would fit, but the 38-46 parts book also lists a 81 C1488 brace. I assume this fits 1938 and 1939 pickups.
This looks like a 45 Degree bend on each end, the large hole looks to be 5/8" the small 1/2 or 9/16. I will scale the photo that was submitted above to 1 inch grid and determine the angles. I should be able to determine the run and travel and figure the offset correctly. I will use 14 gauge. Should stand up good, Sunday is monkey around day this week. I'll post a photo of what the monkey (me) comes up with.
Click on my name, view profile, opens up my CP to you and click on my albums, lower right hand corner one says apatchy, PM your shipping info and I will put it in the big brown truck to you.
