40Pickup
Some pics from assembly the transmission.
Start with blasting.
Some deburring.
Primed and case into a stand
O-ring groove in countershaft.
Now I know that the Canadian cluster gear requires Canadian rear thrust washer, according to Mac Van Pelt is not available anymore, so I made a drawing and water cut it out.
A little turning required at the back.
Some deburring.
Installing clutch shaft bushings.
O-ring on reverse idler shaft.
Counter shaft.
Some deburring.
Some deburring.
Counter shaft.
