40Pickup's, transmission pics .....
40Pickup
Some pics from assembly the transmission.
Start with blasting.
Some deburring.
Primed and case into a stand
O-ring groove in countershaft.
Now I know that the Canadian cluster gear requires Canadian rear thrust washer, according to Mac Van Pelt is not available anymore, so I made a drawing and water cut it out.
A little turning required at the back.
Some deburring.
Installing clutch shaft bushings.
O-ring on reverse idler shaft.
Counter shaft.
Lock pin.
Cleaned bolts.
Grease fittings in place.
Thread Sealant.
Rear mount.
Shift lever, some welding and grinding.
Lock pin work.
Rear mount in place.
Clutch shaft and fork in place.
Time for some painting ...............
Thanks Jorgen.
Jorgen..nice pics and looks like you've got a good reference book to asist you. For future reference, we had a small bunch of those rear thrust washers (Canadian export type) made and are available now. We use p/n C8M-7129..........Mac VP
Sure looks like a job well done to me!
Very nice post.
That dab you added to the ball of the shift lever was poetic.
Our FordBarn buddy Cecil/WV has a 40 pickup, and he's a transmission guy also (among dozens of other talents). He's on the road right now heading for Tahoe.
-VT/Jeff
What a great post! I really like the way you work, and the photographic sequence is great.
Mart.
Nice work and pictures! I went NUTS a few years ago trying to ID one of those washers for a guy on the HAMB...I think it took me a week of digging in my bunker of knowledge before I located its picture and info in an ancient Canadian catalog. Then he went nuts for several weeks locating a usable one!
I used a roll pin like the one you picture on your throw out shaft... And, I came to regret it.
I used it on the outside to fasten the arm to the shaft. I found that I had to adjust the clutch- and didn't know why... The roll pin was springing under load and gradually fell apart...
At least I could get to mine, yours will be hard to replace.
Use a grade 8 bolt...
Karl Wolf, Thanks for your point of view. The idea of ​​the roller pin was that it would fill up the hole and get away from any movement.
I think if the roller pin is too short the ends of roller pin would collapse before a roller pin which extends by at least half the diameter outside, if possible you can beat in a thinner roller pin or a masiv pin inside.
But probably not reach it up to the same strength as a grade 8 bolt!
So maybe I should change to a grade 8 bolt.
/ Jorgen
Great example of machining ability. Good how to on -o-ringing the shafts to stop oil leaks. First job out of high school was a machinist. Didn't forget those skills 50 years later building a '32 hot rod with a Bridgeport & lathe for help.
