I am looking for the point settings for an early FE 406 Ford duel point distributor. Also need a part # for the points. Are 54-56 V8 points the correct points for this distributor? In the end what is total dwell? Thanks
My 406 dual point dist takes the "straight" points but they are not the same as the 6 cyl straight points. Found that out the hard way. The difference is the rubbing block is on the opposite side of the point arm. They can be hard to find. I picked up mine on epay.
Do you know if the points were the same as the 55 and 56 V8 points?
