philipswanson
Your going to get this figured out, and when you do we all will have learned a lot.
[/QUOTE]
I second that!
I second that!
Got the leak tester and hooked it up to each cylinder at top dead center. I put 100 psi into each cylinder and got the following results:
#1 cylinder held 90 psi
#2 cylinder held 65 psi
#3 cylinder held 60 psi
#4 cylinder held 65 psi
#5 cylinder held 75 psi
#6 cylinder held 90 psi
#7 cylinder held 75 psi
#8 cylinder held 75 psi
Each cylinder tested lost the air pressure through the intake valve with air coming out of the block in the intake valve opening.
Today I took both heads off the engine and took all the valves out of the block. Here is what I see: #2 cylinder intake valve guide was stuck in the block when I tried to take it out. Surface sealing of the #2 intake valve against the seat was not uniform around the intake valve rim. Same deal on cylinder 3, 4, 7, and 8. Intake valve guides were stuck in the block, and surface sealing of the intake valve against the seat was not uniform around the intake valve rim. The exhaust valve guides were not stuck and the exhaust valve rims look like they were making an acceptable seal with the exhaust valve seat. I am going to clean up the valve seats and go with new stainless steel valves, new one piece guides, and new Mercury heavy duty valve springs. Looks to me like all this trouble and time lost is nothing more than a bad valve job on a low mileage rebuilt engine with less than 2000 miles since the rebuild. Odd the intake valves are the problem to me, and the compression decreased so quickly and uniformly on 6 of the 8 cylinders. What do you think?
Did you perform the test I suggested in my post #80?
What was the valve to guide fit like?
I'd assume the stuck intake guides had seals on them, the exhausts did not? A pretty common situation.
It sounds like you're lucky 2 of the cylinders had compression, it does sound like a bad valve job.
when you get your new valves, just for confirmation, drop the new valve in, and check with the blue stuff to see where your contact area's are, and maybe get away with just lapping since its pretty new. long chance, but the reason i say this is you mention using a stone to do seats. in the car, a much cleaner method would be the new way seat cutters. easier mess to clean up, no stone grit flying around in your new motor. best wishes
i gotta add some more or i will lose sleep on this one! normally, you have a spring on your pilot, and you only briefly touch down on the seat, and the spring pushes the stone off. briefly, as in, the stone cuts quick. if you are grinding for seven seconds, you cut the hole bigger, and put the seat out to the edge of the valve. and, if really grinding for 7 seconds, its darn near time to true the stone again. and theres that much more stone grit to clean up. if your motor builder guy really had the seats that far off, well maybe your new pilot is trying to make a whole new center. with the 3 different stones it can be done, but you end up lower, and lower in the deck. you want the actual seat contact about a 1/16th in from the outer edge of the valve when done, and the valve slightly proud of the deck. i hope i am telling you things you already know, best wishes
