L78CHEVELLE
New stock camshaft purchased from well known southern Ohio supplier.
If the cam was that worn down the valve clearances would have opened up.
I'm thinking the valve lash is off. Bring each valve to max lift and rotate another full turn. Then adjust the lash.
It ran good for 2,000 miles with the valve lash the same as it is now. Would that not eliminate the valve lash as the cause?
Not if the degradation is due to burnt valves. Run them too tight and they will burn. Not having an engine open currently to check your adjustment technique, frankly I don't know if it is valid. I do know that is not going to put you directly on the heel of the cam. You mention your engine was built. When assembled, who adjusted the valves initially? Was it you with the method you have described?
A gradual degradation of performance as a result of compression loss, to me anyway, screams burnt valves.
Burnt valves could be the answer, but would all the cylinders react the exact same way going from 100 to 65 at the same exact time? I have only used straight gasoline in the car since the rebuild.
before you take anything apart, do a cylinder leak test to see where the compression is going. if you dont have the fancy tool, i dont, you just weld an air fitting to an old spark plug, screw it in, get that cylinder to TDC and put low pressure, like 20lbs to it and listen. air out the carb=intake valve. air out the exhaust pipe=exhaust valve, and air out the oil fill/breather cap=rings. if you get all the same valves, i would suspect cam timing. this one is a puzzler!
Hi L78CHEVELLE; If it's a faulty compression gauge that will take you back to carburetor and or ignition, Craig.
Hi L78CHEVELLE; I'd make sure it's not a faulty compression gauge before I took anything else apart. Good luck, Craig.
Post your procedure for compression testing when you try new compression gauge etc Something might be different which might give us a clue to why compression drop across all cylinders. Mike
