I doubt you will find a 4 carb intake that will take 94 carbs. The only ones I've ever seen will only take 97's. Walt
The carb with the vacuum port on the side is for the 49-53 Ford 8BA engine. The ones without the port are 48 and older. The port on the side is made for a vacuum line to the post dist. vacuum advance. Walt
