40 Ford Heater
HC&ME
New member
Looking for a working 1940 Heater ! Please let me know if you know where I can find one.
Thanks for the help! Michele
Try Larry Caplan 19401 Clymer St. Northridge, Ca. 91326 818 366 9178 He may have what you want. He works on heaters and has a good supply. It has been some years since I dealt with him but he did good work.
Let me know if tou contact him.
If it's a 39/40 hot water heater you are after make sure it only has the 2 doors.
3 doors are for the later model cars.
Both they and the hot air models come up on ebay from time to time.
Prices for both types seem to run around $300 - $450.
There are a lot more parts to the hot air heater.
Hi all; Remember the swtich and wiring! Also the motor has to work in all modes. Newc
Where is the stock mounting position for a 40 ford hot-water heater in a Tudor Deluxe?
Here's a picture. I have copies of the template if anyone needs one.
Thanks! That is the place where my 46 heater is. My 40 does not have a heater but the previous owner put the fuse box where the heater belongs. What I have for the Fordy is a Zephyr model Tropic Aire. Is there templates to be had for that heater. And does anyone have info of the Tropic Aire being used in a 40? MY 46 circulates through the driver side bottom radiator hose and the passenger side head. Is a stock 40 Ford set-up like this?
Make your own template out of card board. I used the very Tropic air heater you have in a 46 Ford. It in my opinion Tropic Air is a better heater than a normal one that they put into Fords. Much better defroster.
I would suggest starting with a copy of "The 1940 Ford Book" from the Early Ford V8 Club https://www.earlyfordv8.org/store-product-item.cfm?id=19&pid=2 so you can identify the correct original heater. If you just want an aftermarket heater from that era that works it will probably be cheaper. Place an ad in the wanted section, here and on the Early Ford V8 Club Site (http://www.earlyfordv8.org). It might be nice to include a picture (from google or EBAY) of the heater you want. A picture will let you catch the guys with old heaters that have no idea what they fit. Good luck.
Charlie Stephens
That is good news Marv. I was wondering about the defrosters. I don't believe my 40 has defroster vents. The heater has a manually operated door on the left side, near the top, I presumed to be the defroster. How many speeds does the blower motor have on your unit. I have no switch for this unit. Can you advise me on that issue?
Thank You for your offer.
Ken Bednar
5568 HWY 175
Hartford WI 53027
( I think this what you meant by "pm") I don't use this site much & still learning. Plus being 73 doesn't help. Let me know if I should do something different.
Ken Bednar
5568 HWY 175
Hartford WI 53027
Only 73? You're a youngster on this site. PM stands for "private message". It's a way for members to contact other members on a one to one basis. If you click on a members name, a menu will appear and on item is' "send a private message". Click on that and you're in business. When the member responds your "private message " alert located near the top right will appear in red. Click on that and you will access his message. Good luck.
Phil
