40 door lock
sid carey
The driver’s door on my ‘40 convertible won’t lock. When I pull the inside door handle up, it doesn’t lock. I can still open it from the outside, even though the inside handle is in the up position. Your thoughts? Thanks, Sid
It's possible the latch mechanism is defective.
It's also a possibility that the remote linkage is not adjusted correctly.
Did the door ever lock from the inside?
