S sid carey Member Jun 12, 2023 #1 The driver’s door on my ‘40 convertible won’t lock. When I pull the inside door handle up, it doesn’t lock. I can still open it from the outside, even though the inside handle is in the up position. Your thoughts? Thanks, Sid
Kube Super Moderator Jun 12, 2023 #2 It's possible the latch mechanism is defective. It's also a possibility that the remote linkage is not adjusted correctly. Did the door ever lock from the inside?
