40 brake master cyl
kurt v
Is there a residual valve built into orig brake master cyl and if not why will a new dual master cyl need residual valves ?
kurt
Yes, 2178.
How far from the master cyl can the residual valves be, my 40 would have the cyl too close to the X frame to fit the residuals ?
kurt
They can be away from the master to a spot where there is room. I like to keep them as close as possible without being crowded...but they will work fine within a couple feet for sure.
Place 10psi RCVs, for drum brakes, in the first hard brake line off of the master cylinder before any tees. The distance is not critical.
