I recently salvaged a 4 blade fan from a '29 parts car, history unknown. While cleaning up the fan, I noticed that there was a small recess (about the size of a woodriff key) adjacent to the main key way at about the same location as where the woodriff key would be. Upon fit up on my '29 roadster water pump shaft, it appears that woodriff key does not slide into the recess (when attempted to twist on the shaft) and fan seems to fit firmly on the shaft as it should.
Has anyone run across this key way arrangement or situation with a 4 blade fan (or other device)? Is it safe to proceed with using this fan blade without a solid key way (ie: one without the recess)?
Thanks in advance for any experiences or advise you can provide.
