JM 35 Sedan
I've had luck using WD-40 and putting the key in and out several times. That helps loosen stuck pins
ME TOO!! Only difference was I used PB Blaster with the little red straw that really shoots the juice deep into the key hole. That's how I got my door lock to work again after having a $35.00 key cut to the cylinder numbers that would not open the lock initially. In other words I wasted my money getting a new key cut because it turned out to be exactly like the ignition key which I didn't know for sure before having the new key cut. It turned out to be years of dirt that built up inside the cylinder and had the spring loaded pins stuck in place. Now everything works well and I have another ignition/door lock key to add to the four I already had
