Rebel Sympathy
Howdy, Boys:
Let's say you had a very low mileage, original '39 sedan with a lot of clutch chatter. And let's say you tightened the chatter rods. And let's say you tightened the motor mount and ****** mount nuts. And let's say you checked the rear shackles and spring mount bolts for tightness. And let's say you then replaced the motor mounts and ****** mounts. And let's say the #!%@!!! car is still chattering badly as ever. And let's say you went into the house and got drunk. And let's say you finally conceded that you need to pull the engine and resurface the flywheel and replace the clutch disc and pressure plate........
What brand of clutch would be the best choice? I know some aftermarket clutches tend to chatter more than others. I'd sure like to get the best brand available. Your knowledge and experience is valuable.
Much obliged,
Mike
Much obliged,
Mike
