I have a 38 that was converted to Hydraulic brakes over 20 years ago. Unfortunately the "authorities will not license it in Aiustralia the way it is... Eemergency brake cable wrapped around the clevis after using the original cross shaft to actuate it.
I intended to remove the cross shaft assembly and install the brace plate that is used in 39 chassis to maintain chassis strength and setup the emergency brake the same as 39. Does anyone know who can supply this part or has a better suggestion?
