i'm going to remove and cut down my steering column tomorrow and install a posie column bushing so it will mate with a alternative ford, steering set-up (don't make me say it) is there anything I need to know about getting the box and column apart? here's what the bushing looks like. . . .
my 64' econoline is, rack & pinion for the 36', I've got to sit the engine in to check clearances so I can come up with the length of column. my seat just got done and I may want to play with how close the wheel is to me, and how far the column pokes through into engine bay. I've never sat in this car yet! the seat was so beat up.Are there any steering columns that are solid?
I'm guessing your are installing a vega box?
Look up ididit steering column on google. Good stuff for streetrod steering.
what the hell does that mean??okay... I guess.
Not sure exactly why you post here but... enjoy!!!
my original question was in separating steering shaft from box. the only reason I posted any pics of the project was that someone thought I wasn't up to the task of installing my front end. if I can take down the pics I will. i'm trying to use as much original pieces as I can on this project, but still have it safe for the area I live. we don't have clear open roads. I shouldn't have posted this group of pics knowing it might upset some. that ones is on me. as far as being banned from the hamb, I never said anything to get banned. they assumed where I was going with my wording. I never typed it in. I was just gone. whatever. i'll keep my car-crafting to myself.
my original question was in separating steering shaft from the box. i'm trying to use as much original pieces as I can on this project.
ford nut;
The steering worm gear is pressed on the shaft.
Given your plan , the only thing left to appear original is the
column drop with the key lock and the ign toggle switch & on/off
plate and the ignition box / contact & plate. With your mask and
shaft replacement/change the lock feature should be disabled
my opinion (safety). Add a modern hidden ign switch use the
toggle for a security Interlock or small current device
Add a later dash starter button with remote old Ford solenoid.
Luck wih neat project---my opinion --try to disassemble
to learn learn Ford stuff and preserve good parts for trade or sale.
How about pictures of column drop , steer wheel and box.
Thanks old Ford fun!!
Gene Tulsa
