sjaakslinger
We're working on a '36, rebuilding the stock brakes, suspension, steering, etc. The king pins that came off the car were toast. We got 2 NOS kits. We're running into a few issues.
- we have 2 opposite king pins, but both marked L. We saw this on 2 others as well. Seems to be wrongly stamped. Anyone ever run into this?
- what's the correct king pin setup? We know where the thrust bearing goes, but which side goes up? Those that came off the car had the 'open' side up, so the flange of the king pin's 'cup' rests on the inner part of the bearing. But I read somewhere here that the closed side should go up.[emoji848]
- Should we put shims under the thrust bearing so it's pre-loaded?
- how is the washer installed? Ridge up? Does the felt washer rest in that metal washer?
Thanks.
Dennis
Verstuurd vanaf mijn SM-G781B met Tapatalk
Thanks.
Dennis
