If I remember correctly from the 1936 pickup I disassembled years ago there are 8 bolts cab to frame, 4 on each side. The front bolts do not go through the wood spacer blocks, the rear 3 pair do. The front and rear pair of bolts had a spring on top of the cab floor (using a castle nut and cotter pin), likely to allow for some cab movement under extreme conditions.
