Firechickenzz
So the day started trying to remove the oil pan off my 36 Ford 3 Window.
I cant seem to get enough clearance with the flywheel to pull the oil pan.
Engine is raised and blocked and will not lift any higher. I have rotated the crank to allow the front of the pan to clear.
At this point I think I'm just going to pull the motor and trans.
Do I need to remove the floor to get at the transmission mount bolts?
Does the rear end need to be disconnected to remove the torque tube?
Thanks in advance. Any other helpful tips will be appreciated.
