bedfordboys24523
It was time to go through the rear on my 35 p/u project, broke it all down put in axle seal's, packed bearing's, every thing went fine. Now onto the torque tube seal, the new seal stop's about 3/4 to 1" from where it should, there is a ridge behind the bearing sleve. Have any of you had this problem?
And do I need to coat the driveshaft with grease before slipping the torque tube on. There is no central bearing.
