There are two rectangular panels above the windshield. Take those out and you can gain access to the hinge screws. Hopefully the windshield will roll out, if so, you will also have to remove a couple of screws that attaches the wind out mechanism to the windshield frame. You may, and hopefully not, have to remove the belt molding that goes all the way across the dash and remove the wind out mechanism while it is attached to the windshield frame. That belt molding is attached with 6 screws that can only be accessed with the windshiled opened out, and 6 screws across the underside of the belt molding where it attaches to the dash. Of course, you will have to remove the windshield regulator handle to remove the belt molding. Good luck.
